Welcome to the TTORA Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. ATTENTION: In an on-going effort to keep this forum spam free, the Forum Admin approves every new account before giving any posting rights to new users. Accounts are normally approved within 24 hours. Sorry for any inconvenience, but verification of every new account is what will continue to keep this forum spam free. |
Thread Tools | Display Modes |
#121 |
My Rig: 2000 Tacoma
^This a good question! I want to learn something.
3.4 TRD ICON C/O Marlin Clutch |
#122 | ||||
I don't recall posting about a filter helping my idle. Its been a crazy couple years. It's possible though, that it did help with idle at the time. I dented the tank badly back in '10 at the hammers. But that was 70K miles ago. I figure if the pump was damaged as a result to that, I would have noticed a long time ago. Though, it did cause me to have to bend the fuel pump bracket a tad so that I could get the pump in. Electrical connections were fine and strong when I pulled the pump out. The thing that might have actually been the cause of the issue? When I pulled the fuel pump bracket out of the tank, since it is bent, the pump doesn't sit on the bottom of the bracket to "hold" it in place. After a couple years of wheeling and the pump freely moving around, I believe the little 2-3" fuel hose that connects the pump to the metal line got loose. When the pump was doing its job the loose hose was letting the fuel go out of the top of that hose instead of up the metal line. Thus, no pressure. I decided that I didn't want to waste my time trying to get that line tight and button everything up just to find out that the pump really wasn't building enough pressure. So, I just put the new pump on, fastened it to the bracket, and went on my way. I'll keep the old pump and fiddle with it if (when) this vatozone one bites the dust. Quote:
![]() I'll gladly send it to you if you want to try sucking on my pump. ![]() Quote:
Really, I'd just carry a spare pump. The tank isn't THAT hard to get out.
99 Single Cab 2.7. Awaiting 3 Link SAS. |
#123 |
14 Year Member Club
![]() Join Date: Jul 2007
Thanks for the info on your situation.
I have done the inline pump thing several times on cars with failed in tank pumps but not on a Taco much less a Toyota. I will be doing a PM filter change in a few days. I will put my vacuum pump/gauge on the line from the tank and see just what it takes to move fuel thru the Taco pump. Actually moving fuel thru the system will be a better measure anyhoo. The price on the Vatozone unit seems reasonable, might just go that route. Edit After a little search, OEM Aisin pumps with screen can be had for about $140. That beats the heck out of around $253 from Toyota online shops.
I Have Never Been Lost, Only Temporarily Without Orientation Wheeling Toyotas Since 1980, Owning Since 1983, Latest A 99 V6 TRD EXCAB and the wife's 08 4R Last edited by terryj5; 07-21-2012 at 06:23 AM. |
#124 |
![]() My Rig: 2000 sr5
stumble feels like out of gas........when it happened to me it ended being a plugged front cat .eventually it melted out the bottom of the vacuum modulator. thank god I was under the 8-80 rule.`
2000 2.7l x-cab 4wd. mods .........yes
#125 | |
The thing that tripped me out, and made me think I was getting enough fuel, was the fact that when the issue started I checked out my plugs and they were fouled out and wet with gas. That's why I started looking elsewhere. I realize I probably look like a dumbass for disassembling half of the truck and replacing $600 in parts before checking the fuel pump, but oh well. At least I have a brand new MAF and IAC, as well as a new to me ECM, and I can keep the old ones as spares knowing that they are still operable. Think I may wrap them up in tin foil and keep them in an EMP safe box JUST incase..
#126 | |
My Rig: 2000 Tacoma
#127 |
My Rig: 2000 Tacoma
Hey Scuba I'm running the P0100 and110. What were your AFRs during your issues?
Mine is stuck at 14.6 and won't swing either way. WOT or throttle cut. Other codes and PIDs were swaying me towards MAF or A/F sensor replacement. Today I just got P1130 and 1135. A/F circuit or sensor. Still when I searched the 100 and 110 codes I got your thread. The fuel pressure is a common possible issue listed( as well as a few more) by the FSM for my codes. Made me wonder... Just going in circles for now. Asked it here and RST:http://www.rocksolidtoys.com/forum/showthread.php?t=444
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| P0120 code/replaced sensor...still runs rough?? | dillsky | Early Tacoma Tech | 3 | 11-09-2011 06:44 AM |
| JOE! p0120, p1135 code help | speedemon55 | Tech | 5 | 03-24-2011 11:32 PM |
| Code P0120 | 5vzfe | Early Tacoma Tech | 5 | 01-12-2011 09:09 AM |
| Cel P0120 | VF'N8 | Early Tacoma Tech | 0 | 07-19-2007 06:43 AM |
| P0120 is this possible? | shovelracer | Performance/Engine/Exhaust | 0 | 10-08-2006 07:38 PM |
