Sponsored Ad
Go Back   TTORA Forum > Desert Tech > Desert Race Rig Build Ups
Thread Tools Display Modes
Old 05-11-2009, 09:45 PM   #1
mpower
TTORA BRONZE Sponsor
mpower's Avatar
Default project old school
well i started working on my truck again , i think the first time since my quad accident back in october.
I thought i may as well start a buildup thread. at first i got the truck to fix and make a daily driver. now i dont know what im doing with it but its getting built up. my plan is for a budget beater as i am also trying to keep my 05 together and that takes up most the coin.
i guess ill start from the beginning
started with a basic tube front end and an ivan dan kit. that was a bitch
and then it passed smog no problems.
Defined Engineering
- Fab Services - Installs - Prep -
Light Racing Jouncestop Rebuilding
King Shock Servicing
Yorba Linda , CA 951-217-4947
definedengineering@msn.com
http://definedengineering.com
2005 tacoma access 4wd sport
getting to be too much to list!!
"I didn't fail 3,000 times. I found 3,000 ways how not to create a lightbulb" -Thomas Edison
mpower is online now   Reply With Quote
Old 05-11-2009, 09:56 PM   #2
mpower
mpower's Avatar
Default the cage
started with a cage and tied it into the front cage tubes. used poly body mounts and use polymounts to mount cage to frame. still needs door bars and gusseting to body
Defined Engineering
Old 05-11-2009, 10:08 PM   #3
mpower
mpower's Avatar
Default bedcage
ditched the bed and got some used hanneman bedsides for a good deal , for an 89^ truck but i liked it better than other versions out there for a 88. started a simple bedcage and gonna mount the foas i got soon.painted the cage cuz who knows when ill get to it again. i also have to get a cell ,exhaust and cut the oem cross tube out its gonna get in the way of the shocks
cant stand the 2tone cab
Defined Engineering
Old 05-11-2009, 10:26 PM   #4
AZNPG
AZNPG's Avatar
Send a message via AIM to AZNPG
Default
looks fucking nice man kep up the good fabwork
orange high smog(714) 289-1088
jlb motorsports(951) 734-4411
AZNPG is offline   Reply With Quote
Old 05-11-2009, 10:30 PM   #5
mpower
mpower's Avatar
Default next up
next step is some door bars and closing up the cab with sheetmetal as well as do some rust repair around the windshield frame(only real rust on truck). some deavers in the rear and finish design on my front suspension. i got all the heims , uniballs , spacers, d35 axle stubs, bms backing plate, foa coilovers and bumps , ect needed to build the front suspension. have some prelim drawings not the best pics but im going the distance, just lack the funds for a 4'x10' sheet of 3/16 chromoly at the moment plus sme other misc odd and ends
limited to approx. 18.5 inches with 10"shocks ,can squeeze 21" out of it with a longer shock but its not needed. arms are 3"over per side and a non oem mounting location for the uppers. i cant recall how many hours i have in drawings , changing things untill the numbers are where i want them . im in the middle of working out castor curves and then all thats left is bump steer but ill work that out on the truck before the spindles are finished
boy do i need solidworks or inventor
Defined Engineering
Old 05-12-2009, 01:58 AM   #6
marnes2986
marnes2986's Avatar
Default
Im really liking this build!
Keep the pics coming!
~MARK
......Anti-BRO
Florent Fabrication
DMZ Fab and Race Prep
marnes2986 is offline   Reply With Quote
Old 05-12-2009, 03:00 AM   #7
menacekustoms
menacekustoms's Avatar
Default
You should flip the white walls on those tires out. I'm just sayin.
Josh
1972 Ford F250 LWB
"El Arreglo"
RIP 2006 BSP Standard Cab Prerunner
Passed on to a lying jackass . . . 11/16/08
Beware of TTORA.com member ROCKRAWLER!!
menacekustoms is offline   Reply With Quote
Old 05-12-2009, 10:22 AM   #8
off_road_punk
off_road_punk's Avatar
Default
im with josh on this one . mike this thing is gonna be sick gnar(in the famous words of brock)
07 tacoma pre-runner l camburg LT l DMZ l
off_road_punk is offline   Reply With Quote
Old 05-12-2009, 10:26 AM   #9
FASTTRUCK RYAN
Default
your truck looks great! I have built a few LT front ends and you are definitly on the right track with the drawings. ps - people that are realy good with solid works, but dont understand suspension geometry, cant do it any faster than YOU with a pencil and paper.
FASTTRUCK RYAN is offline   Reply With Quote
Old 05-12-2009, 10:59 AM   #10
VietNguyen82
VietNguyen82's Avatar
Default
Thanks for posting this project, looks like it's going to be very educational. Good work!
2005 Tacoma Prerunner
4.0 V6, 6sp mannual
TrueFlow XDI intake
JBA Headers
Magnaflow Exhaust
1999 Mini Taco, JD Extreme kit
Found a new home at Richer Racing http://richerracing.com/
VietNguyen82 is offline   Reply With Quote
Old 05-12-2009, 11:46 AM   #11
mpower
mpower's Avatar
Default
thanks guys.
i cant stand whitewall on tires i know it would make it look more oldskool for the build but those are just street tires anyhow, maybe some 33" bfg allterrains with the whitewalls out when its all completed but not these.
right now im thinking of getting a jaz fuel cell to put in the back so i can finish the rear end untill i get some deavers and or a sheet of chromoly. this thing needs a suspension so i can go out and kill the motor to make way for a gt28rs and low comp lower end
Defined Engineering
Old 05-12-2009, 01:02 PM   #12
menacekustoms
Default
You should get some BFG A/Ts and put Port-O-Walls on them. That would trip people right the fuck out! White Wall BFGs on a caged LT truck?! My mind is officially blown!
Josh
1972 Ford F250 LWB
"El Arreglo"
Old 05-12-2009, 02:47 PM   #13
VietNguyen82
Default
http://www.jegs.com/i/JEGS/555/15515/10002/-1
How bout this fuel cell? Its says Jegs but I think its an RCI fuel cell, does anyone have experience with these? looks like a Jazz but almost half the price at $219
4.0 V6, 6sp mannual
TrueFlow XDI intake
JBA Headers
Magnaflow Exhaust
Old 05-12-2009, 05:06 PM   #14
mpower
mpower's Avatar
Default
idk,im going with jaz because ive seen a lot of them on desert trucks and havent heard any problems.this is the one im looking at but its 22gal .also a big thread on race desert about them .
http://store.summitracing.com/partde...5&autoview=sku
now that i look at it the jegs one is not a bad deal especially for a 32 gal cell.
the jegs one dosent have foam(but can be added, and can get pricey for a 32 gal cell) and its spot welded instead of seam welded like the jaz( could only be a problem if the liner has a leak).
other than that the filler cap is integral to the fittings and dosent have an option to mount a 45* neck at any clocking position which is only a concern where the tank filler on top of the tank is a hard to reach place.
im lookin at it now because it would fit in the back a little better than the one im looking at
Defined Engineering
Old 05-13-2009, 09:48 PM   #15
Happysmiley
Happysmiley's Avatar
Default
Rad! I love this build.
-Fabien
Happysmiley is offline   Reply With Quote
Old 05-26-2009, 01:09 PM   #16
off_road_punk
Default
any new news mike?
Old 05-26-2009, 03:23 PM   #17
mpower
mpower's Avatar
Default
Originally Posted by off_road_punk View Post
any new news mike?
nah , i just work on the truck when i can . im busy tring to make money at the moment, got a jeep to do this week , i got to prep my boat next week to sell it and try to figure a body mount solution for my 05. i figured no rush since summer is basically here , ill work on it over the summer and have it ready for next season.
hows your truck doing ? u get it back yet? sucks to hear , now im going to carry a extra one of those adaptor plates just in case now. guess i better get my driveshaft safty loops in that have been sitting around for awhile also.
Defined Engineering
Old 05-26-2009, 05:51 PM   #18
off_road_punk
Default
no its still at DMZ. tim is gonna gimme a call tomorow. i hope my gears are ok im really concerned about that and my rotors. when i got towed out of the desert by another truck he told me to keep some tension on the strap so i did, and the next thing i know smoke it comin up from under my truck and i look and saw my rotors were red hot! this weekend was f n expensive
Old 05-26-2009, 05:52 PM   #19
off_road_punk
Default
anyway about your truck... that thing is gonna sweet!!!
Old 06-11-2009, 06:37 PM   #20
Burns85
Default
any progress?
Burns85 is offline   Reply With Quote
Old 06-13-2009, 07:45 PM   #21
mpower
mpower's Avatar
Default
Originally Posted by Burns85 View Post
any progress?
negitive, havent had any time . on the back burner for a little bit.
i gotta pay some attention to my 05 , i got my springs back from deaver, gotta make new shackles, new bump strikers, limit straps and revalve, also noticed that the 3rd member seal is leaking and my u-joint to flange adaptor is showing signs of fatigue .so thats a day of work right there to pull the 3rd inspect and reseal , not enough time in the day as usual. on top of that my 1/4" alum skids are done getting bent up so i have to finish installing those also
i was thinking about selling my 88 and just concentrate on my tacoma but im shure ill get more for it if its done , when ever that may be .
Defined Engineering
Old 06-14-2009, 12:05 AM   #22
razr
Default
Hey mpower
What bender are you using? I've been looking at the model 3. Just curious what you're using.
razr is online now   Reply With Quote
Old 06-15-2009, 09:24 AM   #23
mpower
mpower's Avatar
Default
i have the model 4 with the hyd foot pump . i like it but wish i would have spent the more money and gotten an enco, so i can do multiple plane bends almost right where the other bend left off , can do a 90* + bend in one shot and dosent have my air comp running with every cylinder stroke
the model 4 is pretty accurate and can do 180* bend in about 4 strokes, takes 2 strokes to do a 90* bend.
the model 3 would probably be fine if you got the room to bolt it to the floor in a nice open space and dont plan on using it for more that personal projects. i got the model 4 so it can be rolled where ever and used without securing it to the floor somewhere and i can bend those 2" tubes without breaking a sweat.
Defined Engineering
Old 07-24-2009, 11:36 PM   #24
mpower
mpower's Avatar
Default a little progress
got a little more done on the the truck. decided that i dont need a/c and heating system so i took everything out. the metal around the windshield was rotting out so i purchased a much better roof from calmini and welded that bitch on. finished up with the gusseting on the upper section of the cage and decided to paint while the roof was off. next is finishing doors bars, adding structure to the cage at front engine cage, closing up the sheetmetal , and tieing the cage into the cab . its a shit load more work but itl be worth it. still debating weather or not to keep the front windshield.
anybody wanna trade some fiberglass/body work + primer , for some fab work ?? damn thing is multi colored now, but i do got the white fender thing going on , shit i know i got a kartek sticker around somewhere too
start
middle
end
Defined Engineering
Old 08-02-2009, 08:11 PM   #25
mpower
mpower's Avatar
Default
got the trans tunnel patched up and got door bars in
Defined Engineering
Old 08-02-2009, 10:08 PM   #26
tacosupreme
Veteran
tacosupreme's Avatar
Default
Sweet man, looks hell-fer-stout. Can't wait to see it running. You should fix the flag on the shop though.
"The ability to quote is a serviceable substitute for wit." - Somerset Maugham
http://www.youtube.com/woodlogan
tacosupreme is online now   Reply With Quote
Old 08-03-2009, 11:11 AM   #27
mpower
mpower's Avatar
Default
thanks logan , flag was fixed that night but u talking about a photoshop fix?
just need a some damn suspension now . i got all the shocks and parts minus metal still to make the arms, just been a bit hesitant on dropping some cash on another 4-500$ of metal at the moment.playing with just finding a used tc-uniball kit just to get it running in the dirt
got shocks for the rear and it can cycle 14-15" no prob in stock leaf arrangement, so im not too concerned with getting the rear done untill the front is done .
been thinking of romping it with the stock suspension for a run since its all in one piece running perfect to see how it does.still needs alot though before its even halfway done
Defined Engineering
Old 08-03-2009, 04:12 PM   #28
marnes2986
marnes2986's Avatar
Default
great update mike!!!!
~MARK
......Anti-BRO
Florent Fabrication
Old 08-03-2009, 09:32 PM   #29
cjbumpers
cjbumpers's Avatar
Default
looks good, there is a guy selling a TC balljoint kit on dezertrangers, just a thought, keep up the good work!
edit: here is the link
http://www.dezertrangers.com/vb/showthread.php?t=96141
06 with stuff
RP FABRICATIONS
looks like we're gonna have to settle this the old navy way, first one to die, LOSES
cjbumpers is offline   Reply With Quote
Old 08-03-2009, 11:27 PM   #30
tacosupreme
Veteran
Default
You should rock it stock for a while and just get a tc kit later. Custom is sweet, but no need to reinvent the wheel if you can find a used kit cheap.
You may not post new threads
You may not post replies
Forum Jump
School help nickcuban Off Topic 9 04-01-2009 09:57 PM
Old school Oppositeboy Off Topic 1 05-04-2007 07:43 PM
school project pics. thenexus Off Topic 1 05-25-2006 04:28 PM
Sponsored Ad
Privacy Policy
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
