Sponsored Ad
Go Back   TTORA Forum > Expeditionary Tech > Expedition Build Ups
Thread Tools Display Modes
Old 10-21-2009, 07:02 PM   #1
fnl4rw29r
fnl4rw29r's Avatar
Default Desert DD Expo
Several months ago I bought a 2004 SR5 V6 4x4 5 spd Taco. I had always enjoyed exploring and camping the desert back country in the desert Southwest. I had a 1994 Jeep YJ previously that was a lot of fun on the trail but as a daily driver, no fun at all. The Tacoma is my only vehicle so while I had visions of building it to go anywhere (the approach that was taken with my YJ), I wanted to learn from the mistakes (which made the Jeep less than street-able) I made before. I wanted to build a vehicle that was equally at home on the trail as on the street. While this vehicle will probably not be going on month long trips through Baja, it will be taking me on long camping and hunting trips. With that said, I'm not sharing this to teach you how to build an all out expedition rig. I am hoping to share my trials and tribulations in hopes that you will take what I've done and improve upon it and maybe even learn something if these are the same intentions you have with your truck. If there's something that I could have done better or something you would have done different, please don't hesitate to post so that I and others can learn! Here is my truck the day I drove it home.
fnl4rw29r is offline   Reply With Quote
Old 10-21-2009, 07:20 PM   #2
fnl4rw29r
fnl4rw29r's Avatar
Default Roof Rack
Having helped plenty of people move in my day, I know how stuff can be stacked in a truck bed. My truck has a cap on the bed. I like the cap because I can keep my stuff out of the elements while on the trail and secure while in town (well... at least more secure than an open bed). I quickly learned that the stuff that I'm accustom to fitting in a truck bed, no longer fit with the cap. I want a roof rack. The Yakima Mega Warrior is the same length and width as my bed. I don't have any pictures of the install but I do have one of the final product. My intention was to keep the control towers as close to the Mega Warrior mounts as possible so the load was better transfered from rack to cap. Unfortunately, I was forced to mount the control towers about 6-7" outside of the mounts due to the thick honeycomb that is laminated inside my cap (of course I drilled 2 holes before realizing it wasn't going to work). So far I'm happy with the rack. All of the Yakima accessories will mount on the Mega Warrior so there is no need to remove it from the cross bars if you want to transport a canoe or bike.
About to float down the Madison River in Montana.
Old 10-22-2009, 03:58 PM   #3
cltypes32
cltypes32's Avatar
Default
Nice truck.
I have just about the same setup as you right now. I was thinking about adding a mega warrior. Did you notice any MPG difference with the rack on?
2002 Tacoma 4x4 TRD V6 XtraCab
A.R.E. Topper
cltypes32 is offline   Reply With Quote
Old 10-22-2009, 04:14 PM   #4
fnl4rw29r
fnl4rw29r's Avatar
Default
I have been paying attention to that. I definately noticed an increase in wind noise. The front fairing helps that a lot. The big problem is that about the same time I installed the rack is about the same time I began running the A/C. The next problem is the tire size has since changed and now that it's cooling off and I'm no longer running the A/C, I still can't tell how big the change in MPG was. Sorry I'm no help...
Old 10-22-2009, 04:49 PM   #5
fnl4rw29r
fnl4rw29r's Avatar
Default Tires
The morons at Findlay Toyota who thought my truck needed smaller tires than originally equipped are a big reason I moved quickly to swap out the undercarriage. The other big reason was the 70,000 miles on the original shocks. I'll do this in sections starting with tires.
Tires:
This took me longer to decide on than the suspension. As I mentioned, I did not want to make it uncomfortable to drive every day. Having driven mudders on my daily driver before, I was hesitant to go that aggressive as to retain some fuel economy, tread life, and peace and quiet. Ultimately I ended up with the BFG All Terrains. I've had them before and other than their incredible ability to pick up rocks and spit them out several miles later and tread chunking off in sharp rocks, I kind of liked 'em. Size was the hardest decision. I read about how most of these hardcore expo rigs are running the 255/85 R16s. They look good. They're probably great off road with 5.29 gears. I did not want to regear. My truck had 255/70 R16 on it (265/70 is stock) and with 4.10s in the diffs it felt like I needed a 6th (maybe 7th?) gear while commuting to work. I wanted something in the ball park of a 265/75 R16 and a 33x10.5. I'd seen the write ups of people running the 33's and how much they'd rub at full stuff. I wanted to be able to cram those tires into the wells without much more than a pinch weld mod. I also seem to be doing a lot of trips down to the lake running through really soft sand and wanted a little bit of extra float. I ended up with 32x11.5s on Wheeler 15" Type Bs. They fit in the wheel wells great. I tried really hard to get them to rub and barely got the front driver side to brush the pinch weld. Easy fix.
Here's the 32x11.5 next to the 255/70 R16
This is the clearance between wheel and caliper. WOW!
Here's the rear's clearance at full flex. Perfect.
Old 10-22-2009, 04:51 PM   #6
fnl4rw29r
fnl4rw29r's Avatar
Default Front Suspension
Front:
I knew I wanted a suspension system, not just a lift kit, so spacers were quickly ruled out. I had read extensively into the coil-over packages that Donahoe (now Icon Vehicle Dynamics) and Sway A Way produced and also into non-adjustable setups like Old Man Emu. I decided to go with an adjustable because at some point I want to have a bull bar. The OME springs come in different rates which is nice, but if in 6 months I decide I want to add a ton of weight (especially with a winch) to the front of my truck, I'll need to order new springs again while with the IVDs or SAWs I can just crank 'em up a little higher. I ultimately ended up buying the IVDs. Not because they're superior to SAW (that is a huge argument that you can read about elsewhere on this forum as I found out during my research). I really only ended up with the IVDs because I got an incredible deal on them and free shipping from Wheelers. I'm writing this about 5K miles after install and so far, so good! They settled just a little bit (probably less than half an inch) and softened up nicely. When I first installed them, they were quite stiff (compared to the Cadillacesque ride I was dealing with before). Body roll almost completely went away and I was no longer slamming bump stops going down US95 at 60 mph.
Here's the IVD next to the stock spring and shock
Here's the brake line clearance. It hits (even after gently pummeling it with a hammer but I don't think I can break it off while turning/ flexing)
Here's what I have after the IVDs were on with the new 32x11.5 R15s (stock rear setup still)
Old 10-22-2009, 05:02 PM   #7
fnl4rw29r
fnl4rw29r's Avatar
Default Rear Suspension
Rear:
I wanted to gain some ground clearance while gaining some flex but without sacrificing too much carrying capacity. I shied away from the Deaver and Alcan 8 leaves because 1) I heard (emphasis on heard... I have no experience with these springs) they lifted a little too much if there was nothing in the bed and 2) because I wanted to maintain my ability to haul a heavy load. I went with the Wheeler 5 leaf packs with the overload spring (built by Alcan for Wheeler's). They flex plenty (they're the springs twisted up in the rear tire clearance picture) and ride great. The shocks are Bilstein 5125s. Enough people were running them and I've heard nothing but good things about them so figured I couldn't go wrong. Happy so far. Again, about 5K miles since install on and off road and the improvement over the worn out stock springs and Kokico shocks is amazing. It eats up washboard, twists through the boulder patches, and handles everyday commuting beautifully. I also took this time to add an extended rear brake line.
Here's what I've got so far: IVDs front, Wheeler 5 leafs, 32x11.5 R15
Rear all flexed out at Wheeler Pass, Mt Charleston, NV. Sway bar not disconnected, left rear sitting on bump stops (stock- not extended), all 4 wheels still on ground.
Extended Brake Line
Last edited by fnl4rw29r; 10-22-2009 at 10:04 PM. Reason: added picture of rear articulation and extended brake line.
Old 10-22-2009, 05:18 PM   #8
fnl4rw29r
fnl4rw29r's Avatar
Default Exhaust
With the addition of higher arched springs came the need for an exhaust hanger extension. I wasn't to enthused about this since the exhaust already seams to be right in the way if I were to drive down any serious drop offs (The mud flaps were gone with the stock suspension for the same reason... and because I already embarrassed myself by getting stuck on one in front of my friends). Below is a picture of the exhaust exit after the extension.
I got a call from a friend who was going on a trail ride with a local FJ club and said it'd be no problem for me to tag along in my Taco. I was excited especially since I hadn't really gotten a chance to run my brand new suspension very hard yet. With the images of me being stuck on a mud flap fresh in my mind, I had to do something to prevent further embarrassment in front of a bunch of strangers when I get stuck on my exhaust pipe. A temporary fix was in order. I took a pipe cutter and cut the exhaust even with the back of the rear tire (didn't want to cut it off too much so that there was still an anti-siphon effect the next time I launch a boat or cross a river).
After removing the unwanted portion of the pipe, there was no longer a hanger supporting the rear half of the exhaust system. This caused it to vibrate and swing a little wild. I was going on the trip in the morning and needed to come up with something fast... Using the old hanger and extension I drilled and welded up a solution. It works well enough that after 5K miles, I have no intention of changing anything until it somehow breaks. I'll keep you posted if it does.
Old 10-23-2009, 05:01 AM   #9
ARB1977
I LIVE FOR THIS
ARB1977's Avatar
Default
Nice. I had the 5125's for 64K, mind you im a mall crawler. Two weeks ago i got this clunking noise going over bumps. Comming to find out the shaft that goes to the bottom of the shock that mounts to the axel broke off...even mall crawlers can get carnage....haha. So i replaced them with ICON remote resevior shocks...wow.
2002 TACOMA 3.4L AUTO 108K
ARB1977 is offline   Reply With Quote
Old 10-23-2009, 01:36 PM   #10
fnl4rw29r
fnl4rw29r's Avatar
Default
Originally Posted by ARB1977 View Post
...even mall crawlers can get carnage.....
HA! That's good. I've read really good things about those remote reservoir Icons. I didn't go with them ultimately because I didn't think I'd be cycling them fast enough over long periods of time to justify the coin. Glad you like 'em. We'll see how long my Bilsteins last and I may end up with some remote reservoirs under there yet.
Old 10-23-2009, 01:52 PM   #11
fnl4rw29r
fnl4rw29r's Avatar
Default Cb
My old man had a CB that was in his truck about 2 trucks ago and hasn't used it since. After little sweet talking, it was mine. It's too wide to mount in the ash tray location (which I think is pretty slick having seen other people mount it there). The only place that kept it (mostly) out of the way and relatively clean looking was next to the T-Case lever. I pulled the boot cover housing thing, which comes off pretty easy, and drilled the mounting holes. I used self tapping screws into the plastic. After repeated impacts from the passenger seat slamming into it, I need to change to nut and bolt because it's getting pretty loose. I have a cheap mag-mount, don't even know what brand, that I put on the roof right smack in the middle and run the cable out the driver side rear window (I have an X-Cab). I hooked up a friend's watt meter to check the SWR and the mounting location is absolutely perfect. Didn't have to change a thing. I had 4 watts forward and the needle didn't even move when looking at the reflected power (it was a 50 watt meter so the resolution wasn't that great).
The biggest problem with the mounting location is not the passenger seat hitting it when accessing the back seat (it barely hits). It's the T-Case lever vibrating against the volume knob while in 4 low on extremely rough terrain. It rubs on the knob and eventually turns the CB off. Not a big deal if you're using it to talk to truckers on road (because you're in 2wd) or if it's only for emergencies but if you're on a trail ride trying to listen to everybody, it gets kind of annoying.
Here's the CB location
Old 10-23-2009, 02:09 PM   #12
fnl4rw29r
fnl4rw29r's Avatar
Default Antenna
As I mentioned, I had been using a mag-mount on top of the cab. Works great but I was tired of knocking it off on low hanging trees (yes we do have trees out here). Surprisingly I only once had it fall off while bombing down a trail @ about 70 mph. I ordered a Wilson 4' antenna and a hood channel mounting bracket. I wasn't a big fan of mounting it on the hood and wanted to mount it out back in the tailgate channel (I realize the hood provides a better ground plane). The install, I think, looks pretty clean.
Antenna mount:
I ran the co-ax down the frame rail with the factory wiring loom and into the cab through the grommet behind the driver's side rear seat. I drilled a small hole and cut a slit in order to slide the cable up into the grommet. I ran the cable under the rear seat, behind the interior side panel, under the carpet, under the door entry guard thing, under the front floor mat, in front of the sticks and into the CB. I would have liked to run the cable under the dash and over to the CB but 20' of cable wasn't enough to reach.
Cable into cab:
I don't know a whole lot about tuning antenna other than you should have a decent ground plane and to adjust the antenna length until the SWR is low enough so that nothing burns up when transmitting. I did not expect this mounting solution to work nearly as well as the roof top mount, but I did expect it to work well enough to be used on trail rides and talking to truckers while making passes or being passed on the road. Well... I can't adjust the antenna enough. I have nearly 50% power reflected back into the CB! Not sure if this is because the ground plane sucks or if maybe my roof rack is too close (roof rack is not grounded however). It is still mounted there but I use the mag mount temporarily until I can figure out what to do. Any suggestions? I'll try anything.
Old 10-23-2009, 02:19 PM   #13
fnl4rw29r
fnl4rw29r's Avatar
Default Pinch Weld Mod
There are plenty of threads on how to do this so I'm not going to give a step by step. I waited for a while before doing this mod because I wanted to let the springs settle a little and rub a bit to get a witness mark so that I didn't cut and hammer more than necessary.
Here's the witness marks:
That was all Could manage to do. I do not intend to disconnect my sway bar so there's only so much front end articulation I'm going to achieve while crawling through the boulders. I'm pretty sure these marks came from me running a trail fast and hard and having the wheels turned slightly when I loaded up the suspension.
I first cut away the plastic fender liner
I then cut the bottom of the weld off
Then I hammered the rest flat and painted it to prevent rust where the paint had chipped.
Old 10-23-2009, 02:45 PM   #14
fnl4rw29r
fnl4rw29r's Avatar
Default Compressor
I want on board air for two reasons: 1) to air tires back up after the trail and 2) to run the air lockers I eventually want to install. I ordered myself the Viair OBA setup for my truck. I got the 400C compressor (33% duty cycle), 2.5 gallon tank, and the 85-105 psi pressure switch. I went with this switch because ARB doesn't recommend more than 100psi in their lockers in order to keep from prematurely blowing seals. I don't want to mount anything in the bed because I want to retain my cargo space (remember this is still to remain a daily driver and should be able to accomplish the tasks of any other truck). I ultimately installed the compressor under the passenger side rear seat. It fits perfectly. I had intended to be able to retain the spare tire tool mounting location but due to my incredible ability to measure once and cut twice, it ended up a little too low. The tools will still fit below it, but they're a little too close and I'm afraid the bag will melt to the compressor case.
Here's the compressor installed under the seat:
Although it fits great, getting it bolted up there is a HUGE pain. If I ever need to remove it for any reason, I'm taking the entire panel out of the truck. I used locking washers all the way around as well as locking nuts to keep it from rattling loose. Hopefully I never have to remove it or retighten it. I did pull the carpet up to keep all the mounting hardware hidden. I also had to build an aluminum bracket to mount the compressor horizontally because the panel it is bolted to is not vertical. Sorry I didn't get any pictures of it before bolting it in. I can probably drop my camera in there with the timer set to get some pics of it if anyone is interested.
This post gets me up to date with what has been done so far. I still need to wire it up, install the gauge (the Lo-Tek gauge pod just came yesterday!) and install the tank. I am open to recommendations for tank mounting location. I had intended to mount it under the truck in front of the fuel tank when I ordered it. I don't like how the drain cock will be hanging out waiting to get ripped off by some rock so now I'm unsure of what to do. I don't really want to put it in the bed, but I will if it wont fit anywhere else.
Old 10-23-2009, 02:50 PM   #15
fnl4rw29r
fnl4rw29r's Avatar
Default First "Expedition"
For fun, here's my first "expedition" in my truck... BURNING MAN!
Old 10-23-2009, 05:45 PM   #16
Geo4X4
Geo4X4's Avatar
Thumbs up
nice trailer, hippy!
great progress, pilgrim.
i dig it
03.Taco.XCab.V6.4WD.TRD.5spd
faster than grass
Geo4X4 is offline   Reply With Quote
Old 10-23-2009, 09:36 PM   #17
fnl4rw29r
fnl4rw29r's Avatar
Default Lo-Tek gauge pod
Just finished installing my new gauge pod. I really only got it to mount the pressure gauge for the OBA but it only came in a 2 gauge unit so I mounted a voltmeter to go with it. Viair includes a mounting bracket for the gauge with the hookup kit that they sell but I couldn't find a really good and clean place to mount it in that configuration. The hardest part was routing the damn air line from under the back seat, under the carpet, under the dash and to the gauge. That tubing is super stiff and hard to work with. It has a ridiculous memory and after being coiled up at the warehouse for who knows how long before I got it, it refuses to lay flat and straight. Here's the results:
All gauges hooked up. Ready to install.
Gauges in the pod. Notice the two small LEDs right above the voltmeter. My plan is to hook them up to the switch for the auxiliary lights that will be installed soon. The green one is for the forward lights, the red one is for the rear lights. This is so I don't end up driving off the trail onto the road with the auxiliaries going or blinding someone on the trail because I forgot to turn the rear ones off. (I'll post this install when I actually get around to doing it)
All finished!
Old 11-08-2009, 05:59 AM   #18
Ritchie
Default
Nice project. I have done similar mods to my '03. I am getting close to completing my projects. A few more little things and I will post progress like you have done here. Great write up.
Questions: 1. Where did you get the gauge pod?
2. Where did you make the connections for the volt gauge?
LaytBra
'03 Reg Cab Pre-runner w/step-side. Dialed in daily driver.
Ritchie is offline   Reply With Quote
Old 11-09-2009, 05:36 PM   #19
fnl4rw29r
fnl4rw29r's Avatar
Default
LaytBra
Thanks for the response!
1)The gauge pod is from Lo-Tek. Their website is www.gaugepods.com
2)The connection for the voltage gauge is the same as I did for the key-on power for my CB. My fuse panel had an empty slot in the top left that is hot with the key on only. I took one of those fork looking connectors, cut one of the tongs off, and plugged it in there. Everything I've run off of this output has in line fuses.
Old 11-09-2009, 05:47 PM   #20
fnl4rw29r
fnl4rw29r's Avatar
Default Wiring Gremlins...
So I finally got around to hooking up the gauge lights for my auxiliary gauges. I obtained a wiring diagram for my truck so that I could wire the lights into the rheostat so they would come on and dim with the rest of the gauge cluster. The first thing I noticed was that instead of a white/ green wire I had a yellow/ green. I wasn't too concerned with this since the other two wires were the correct color. My problem is that when I spliced into the wire out of the rheostat, the lights in the auxiliary gauges worked backwards from the rest of the cluster... Yea, they came on but only when I dimmed out the rest of the lights. In other words, when I dimmed the instrument cluster the aux gauges brightened and when I brightened the instrument cluster the aux gauges dimmed. Anybody have some advice? I have them hooked up to the power in to the rheostat right now so they come on with the headlights but don't dim.
Old 11-09-2009, 08:29 PM   #21
loudboy
loudboy's Avatar
Default
Reverse the wires?
I'd have to see a diagram to tell you more, I havent seen how these are wired up.
Nice looking truck though, there are definitely some ideas there that I would like to end up using in the future
...pretty sure I only like wheeling so that I have an excuse to work on my truck when I break something....
Originally Posted by Jomentum View Post
Kids don't eat enough dirt these days !
A person does not go to the hardware store because he needs a drill, he goes to the hardware store because he needs a hole.
loudboy is offline   Reply With Quote
Old 12-07-2009, 10:08 PM   #22
rdrttoy
rdrttoy's Avatar
Default
nice lookin truck man. what part of vegas are you in?
rdrttoy is offline   Reply With Quote
Old 12-08-2009, 10:05 AM   #23
drabnor
Home Grown Tacoma
drabnor's Avatar
Default
tacos are backwards, the rheostat controls the ground not the power
TBH IE division
Oh boy, dinner time! The perfect break between work and drunk.
If you want to know if a trail is too hard - GO WHEEL IT! If your trucks breaks, or you die - it was too hard.
drabnor is online now   Reply With Quote
Old 12-09-2009, 11:03 AM   #24
etan
Default
Nice taco! Is there a lot of wheeling around the vegas area? I was thinking of planning a road trip there and would love to do the stuff you're doing.
98runna
etan is offline   Reply With Quote
Old 12-09-2009, 10:21 PM   #25
treehugger
treehugger's Avatar
Default
Nice. I've done similar things to my truck for similar reasons. took it to burning man last year (where i manged to lock the keys in it while it was running and had to break in with a coat hangar). any future plans? bumpers? winch?
Black 2000 TRD V6 Auto
Icon Extended Travel Coils with Camburg UCAs
Deaver custom 9-pack with 7100 12" short bodies
Rear shock relocation and ubolt flip
bentup winch bumper with warn m8000
full budbuilt skids and marlin crawler elocker guard
F/R diff breather extension with filter
Demello hybrid wraparound rear bumper and HD sliders
Viair 200PSI OBA
treehugger is offline   Reply With Quote
Old 12-19-2009, 05:50 PM   #26
fnl4rw29r
fnl4rw29r's Avatar
Default
Thanks! I'm way South between Seven Hills and Southern Highlands.
Ahhhh.... But it still lit up. Wouldn't I have no lights on at all if both ends were grounded or am I missing something? If I hook the + for the lights to a hot with key on and the ground to the rheostat it should work correctly?
The place I used to run my Jeep in high school just became a conservation area "Closed to all mechanized vehicles including (but not limited to): Mountain Bikes, Hang Gliders, and Horse Drawn Carriages." There's still some stuff within reasonable distance. Theres a trail up over Red Rock down into Lovell Canyon, Wheeler Pass over Mt Charleston, Burrow Wash down to the Colorado River, if you want to drive a little farther Logandale has some really good aggressive stuff but it might be getting close to shut down too from what I hear. If you're serious about finding some trails, I can send you some maps with arrows and bullseyes.
AH! I give an extra set of keys to one of my camp mates before we even hit the road because I'm terrified of losing my keys. Lots of future plans. Waiting for work to be a little less turbulent before I drop some cash on ARB lockers. Also want to throw rock sliders under it and wire up some auxiliary lights (which I have -lights not sliders- just need time to do). Bumper and winch are on my wish list but far enough down I really haven't done anything more than think about 'em.
Thanks all for the replies.
Old 12-19-2009, 10:41 PM   #27
drabnor
Home Grown Tacoma
drabnor's Avatar
Default
yea thats how it should work
TBH IE division
You may not post new threads
You may not post replies
Forum Jump
Offroad - Expo Fonz Desert Wheelin' and Racing 61 10-15-2009 06:33 AM
4x4 expo dennis1er Plan a Trail Run 4 10-02-2008 03:23 PM
7th annual expo yj4play Other Clubs Upcoming Events 0 12-23-2006 10:39 PM
Back from the Expo Reebles Past Events 9 10-28-2005 11:05 AM
Off Road Expo cb77DEMELLO Sponsors Promotions 1 10-06-2005 10:12 AM
Sponsored Ad
Privacy Policy
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
