Home | Events | Emergency Rescue Team |
Sponsored Ad
Go Back   TTORA Forum > TTORA Chapter Forums > Official TTORA Chapter Forums > Colorado Chapter > Performance/Engine/Exhaust
User Name
Thread Tools Display Modes
Old 01-12-2011, 08:30 PM   #1
Yanman
Yanman's Avatar
My Rig: 88 Hilux Pickup
Question Ring and Pinion MFGRs
So every one knows that if you go to 33" tires you go with 4:88 gears and 5:29s with 35s.
But what I want to know is who are the good manufacturers of these ring and pinions?
Its all
88 Hilux Pickup Trail Rig - Build Thread
03 Taco DD
Yanman is offline   Reply With Quote
Old 01-12-2011, 08:47 PM   #2
tacotoy
Dun DUn DUN!
Default
mmmm depends on the motor and transmission for your conversion, i have heard/seen of 4.88 for 35's with a 3.4 and auto.... its more by preference, i know that nate runs 5.29's with a true 35 and he loves it. i have also seen and driven 4.88's with 35's and it was a huge improvement over stock.
Yukon and ECGS are the 2 that come to mind
99 Taco with 5 inches of lift and some toys....
12 Jetta TDI with some toys coming
"don't drink and park, accidents cause people!"
tacotoy is online now   Reply With Quote
Old 01-12-2011, 08:54 PM   #3
Yanman
Yanman's Avatar
Default
Good point, I keep forgetting the details to better assist those who are trying to help me.
So my '88 has a 3.slow with a 5spd and I'll probably run 35s.
Its all
03 Taco DD
Old 01-12-2011, 09:43 PM   #4
hunter4runner
Banned
Default
yukon #1
hunter4runner is offline   Reply With Quote
Old 01-12-2011, 10:32 PM   #5
My Rig: 1999 tacoma
Default
ECGS doesnt make gears.
Persicion is the new hot one to get. Yukons are good as well.
The setup is the important part. I would talk to whoever you are gonna have set up your diffs and get the brand that they get the best patterns with.
I like goats
87 cherocar
ike is offline   Reply With Quote
Old 01-13-2011, 09:11 AM   #6
orange crusher
#1 Member
orange crusher's Avatar
My Rig: 87 runner
Default
My yukons are awesome! I love them. Mythica turned me on to them. They are so quiet!
87 runner on 42s "bad luck"
orange crusher is offline   Reply With Quote
Old 01-13-2011, 10:32 AM   #7
Avsfreak1234
Avsfreak1234's Avatar
My Rig: 98 Taco, 35s n Stuff
Default
I got precision from ECGS and had thefatkid set them up. works great so far. beat on em in moab for a week and they did fine. quiet. pulled the diff after a few heat cycles and the pattern looked great (mostly due to setup).
Colorado VP
Avsfreak1234 is offline   Reply With Quote
Old 01-13-2011, 11:18 AM   #8
thefatkid
My Rig: Your Mom
Default
Lies!
I like Precision the best, they have the best inital setup pattern. Yukon (not the value line) is on par with Richmond. The yukon value line and genuine can get a decent pattern, though not consistent from tooth to tooth.
I've set up one set of Trail Gear gears, they set up ok, I was not told if they had any abnormal nosie (should not have but you never know). I'd say they were yukon value line quality.
Anyone else making/rebadging gears out there?
1996 4runner outfitted with a ton of ARB stuff. Got some Warn Items also
1983 Hilux, nuff said
thefatkid is offline   Reply With Quote
Old 01-13-2011, 11:25 AM   #9
ShowStop
Member Dismemberer
ShowStop's Avatar
My Rig: 95.5 Tacoma
Default
Nitro gears (rumored to be made by Precision) are also good quality.
Next Socal TTORA event - Miller Jeep Trail - June 22
www.ttora-socal.com
TTORA-Socal on Facebook
ShowStop is offline   Reply With Quote
Old 01-13-2011, 12:35 PM   #10
thefatkid
My Rig: Your Mom
Default
That is right, Nitro. I installed them when I was working at Slee. They were a nice high quality gearset.
Old 01-14-2011, 06:41 PM   #11
ScottyC
TTORA SILVER Sponsor
ScottyC's Avatar
Default
Every set of Nitro Gears I have set up have been Yukon. The "K" for Korea is a dead giveaway. FWIW, Yukon is cutting gears for a lot of companies these days.
TG is Yukon. Same exact gear as a Nitro Gear. The new G2 gears from 4WP is also the same. They are quality gears. Every one I have setup (likely around 100 sets has been very good patterns.
ScottyC is offline   Reply With Quote
Old 01-14-2011, 08:29 PM   #12
Asha'man
Asha'man's Avatar
Default
Brian set up Nitros when he did my rear diff, have not had even a hint of any problems.
- Brian
Daily - '97 Tacoma SR5 - 3.4 5spd - stock
Rig - '86 4Runner - 22RE 5spd - lifted, locked, geared, 33's, 85% armored
Car - '95 Lexus SC400 - 1UZ-FE V8 auto, 3L2, black leather, 222K, coilovers, exhaust, '97+ body, fresh paint
Bike - '78 Yamaha XS650 - 13K miles, rescued and titled, restomodded
Property Bitch - '85 Xtra cab 2wd - 22R, 5spd, two colors, holds 12 bales of hay
Asha'man is offline   Reply With Quote
Old 01-14-2011, 08:46 PM   #13
thefatkid
My Rig: Your Mom
Default
I remember from back in the day at Slee (almost 5 years now) Nitro had the same markings as Precision. I have not set up a set of Nitro gears in a long time. Normally Slee used Precision untill there was a shortage, I installed a couple of Nitro sets then went back to Precision.
The trail gear set I have right now doesn't match the Yukon sets I have done. The finish on the pinion is different. I'm not sure if they match the value line though.
Wasn't there a US gear brand also? They had some sort of crest stamp on the ring.
I wouldn't be suprised if they all come of the same machine now. Quality control determines who gets what gears and how much they cost. Final finishing could also explain different gear manufactures.
Old 01-18-2011, 11:55 AM   #14
sovereign
sovereign's Avatar
Default
ECGS is only sending out Nitro. The other options are gone. Did they do this as a cost cutting measure?
2002 TOYOTA TACOMA EXT CAB 3.4 4X4 AUTO TRD. 5.29s, ARB RD90, SAW 2.5LT COs w/700# coils, Camburg UCAs, Alcan 8 leaf rear, Bilstein 5125, Tundra brake mod, TOYO M/T 255/85r16, Scangauge II, @ 77k miles
sovereign is offline   Reply With Quote
Old 01-18-2011, 08:05 PM   #15
My Rig: 1999 tacoma
Default
More than likely. I dont think they are making gears branded precision anymore though also.
I like goats
87 cherocar
Old 01-18-2011, 09:49 PM   #16
Avsfreak1234
Default
mine were precision that I got 4 months ago
Colorado VP
Old 01-18-2011, 09:52 PM   #17
My Rig: 1999 tacoma
Default
Still leftovers. When I regeared the rears were still fairly easy to find, but the fronts were fairly rare.
I like goats
87 cherocar
Old 01-19-2011, 10:24 AM   #18
Volcom
Volcom's Avatar
Default
Mine are Motives. Box said "Made in India". Held up to 39.5" Iroks, dual ultimate crawler, and big big rocks.
Addicted Off Road
Originally Posted by DIRTCO
If you build an F-Toy it better be the Toyota motor home class, because your going to be living in it! Your wife would kill you if took on that big of a project!
Originally Posted by poorboyota26
Yeah it needs more troyangulation
Volcom is offline   Reply With Quote
Old 01-19-2011, 10:48 AM   #19
sovereign
sovereign's Avatar
Default
bump.
Old 02-24-2011, 03:06 PM   #20
Yanman
Yanman's Avatar
Default
So I'm thinking about getting in on this group buy for some Nitro ring and pinions:
http://ttora.com/forum/showthread.ph...15#post2121815
And I've been quoted $669 for 5.29 front and rear with shipping.
What I want to know is this price a good price or is it out of line and are the Nitros worth the cost.
I did some of my own research and found a place that sells Precision Gears and they go for $160 less than what I've been quoted on this group buy.
Its all
03 Taco DD
Old 02-24-2011, 03:49 PM   #21
mrdoug
mrdoug's Avatar
My Rig: 3.4 swapped 85 xcab
Default
Caution on places that still list Precision gears. I just ordered mine a few weeks ago, ECGS called to tell me they didn't really have any, and that they weren't aware they were still listed as available on their website. They sent me Nitro's for the same cost in replacement.
Just Differentials listed and shipped precision's
I paid:
$190 for a 5.29 e-locker
$225 for 5.29 8.4
that's just gears, not master install kits, which are just as expensive as the gears (or more)
FWIW, when ECGS called me, they mentioned that the percision gears changed towards the end and weren't very high quality. Now, they couln't be more vague about when this happened, what specifically changed or what specifically didn't meet their standards. About the only portion of this that holds any weight is that it was somebody from a (dedicated) gear supplier.
de·gen·er·ate
mrdoug is offline   Reply With Quote
Old 02-24-2011, 03:55 PM   #22
sovereign
sovereign's Avatar
Default
I paid:
$225 for 5.29 8.4
You returned the Nitros?
Old 02-24-2011, 04:01 PM   #23
mrdoug
mrdoug's Avatar
Default
No, I didn't return anything. ECGS saw that I ordered precision and sent me nitro's instead (for the same price).
de·gen·er·ate
Old 02-24-2011, 04:04 PM   #24
sovereign
sovereign's Avatar
Default
Yes, that is what they told me as well, as mentioned in my post earlier. I haven't ordered yet, though. Still too cold out.
Old 02-24-2011, 06:28 PM   #25
Avsfreak1234
Default
good to know, cant wait for my rear diff to explode now!
Colorado VP
Old 02-24-2011, 06:56 PM   #26
My Rig: 1999 tacoma
Default
Gear setup is more important than anything for gear life.
I like goats
87 cherocar
Old 02-24-2011, 09:12 PM   #27
Yanman
Yanman's Avatar
Default
But is $669 a decent price for the gears, master install kits, solid spacers?
Never bought gears before, so give a noob a hand.
Check that, I decidied to pass on the group buy and keep putting $ towards the SAS/Lift.
Its all
03 Taco DD
Old 02-25-2011, 08:08 AM   #28
mrdoug
mrdoug's Avatar
Default
yes, that's a deal if it comes with the master install kits...
What I just paid for the Master install kit:
elocker: $220
8.4: $231
I did not go with the solid spacer, but I think they are another $20 each
And damn you for making me think and re-think about what I would have saved if I'd waited another 3 weeks.
de·gen·er·ate
Old 02-25-2011, 08:21 AM   #29
Volcom
Volcom's Avatar
Default
Are the diffs already built? I'd highly suggest running solid spacers in Toyota diffs.
Addicted Off Road
Old 02-25-2011, 09:44 AM   #30
ajax
ajax's Avatar
Default
picked up nitros with solid spacers for fzj 80 and there were 700 bucks with 2 toyota master rebuild kits would think mini truck,or tacoma should be lot cheaper since my rear is 9.5 and front is the reverse cut high pin
ajax is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
v6 5.29 used ring and pinion phi564 Parts/Electronics/Wheels & Tires For Sale 1 09-27-2010 09:15 AM
4.10 ring & pinion or 3.90 one_lastword Wanted 9 07-09-2010 12:04 AM
5:29 Ring and Pinion Snorkie Classifieds 3 01-10-2009 09:10 PM
3.91 ring and pinion tllstaco Hot Deals/Good Finds 14 05-27-2007 08:25 AM
4.88 Ring and pinion TacoDell Early Tacoma Tech 14 11-12-2006 10:23 PM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
