Home | Events | Emergency Rescue Team |
Go Back   TTORA Forum > TTORA Chapter Forums > Official TTORA Chapter Forums > Colorado Chapter > Performance/Engine/Exhaust
User Name
Thread Tools Display Modes
Old 07-28-2011, 07:41 AM   #1
mrdoug
mrdoug's Avatar
My Rig: 3.4 swapped 85 xcab
Default Auto Tranny Temp link
I ran across this link on Pirate. They were specifically talking about a C4 transmission in a race rig. It doesn't specifically say this info applies across the board for all fluids and transmissions, so I wanted to see what people here thought (hopefully FatKid will chime in).
http://www.digi-panel.com/trannyoil.htm
OIL TEMPERATURE MEASURED AT CONVERTER OUTLET TO COOLER:
300° F=
The maximum allowable temperature. This is the recommended place to install a temperature gauge or sensor. Do not allow the converter outlet temperature to exceed 300° F. The temperature at this location will vary significantly because of load, hill climbing, etceteras. If the temperature reaches 300° F, reduce throttle. To lower transmission temperature with transmission in neutral, run the engine at 1,200 RPM for at least 2 - 3 minutes while keeping a close check for signs of engine overheating. A transmission in a heavy throttle, stall condition (a typical situation is rocking a vehicle stuck in mud, sand, or snow), may increase temperature at a rate of 1° degree per second of stall.
OIL TEMPERATURE MEASURED AT OIL PAN OR SUMP:
150° F=
The minimum operating temperature. Note: It is possible in low ambient temperatures to overcool the transmission with auxiliary oil to air coolers. Oil to water coolers in standard factory radiators will normally not overcool a transmission.
175-200° F=
Normal pan oil temperature operating range.
275° F=
Maximum allowable oil pan temperature for short durations during long hill climbs.
300° F=
Damage occurs to internal transmission parts, including warpage of metal parts, degradation of clutches, and melting of seals. Transmission oil oxidizes, (forming varnish-like substances causing further clutch slippage and compounding heat build up) and transmission oil life is extremely short.
AUTOMATIC TRANSMISSION FLUID LIFE / TEMPERATURE RELATIONSHIP:
Automatic transmission oil can provide up to 100,000 miles of service before oxidation requires replacement, at an operating temperature of 175° F. Above this temperature, the oil oxidation rate doubles with each 20° degrees F increase in oil temperature. See chart.
DEGREES F - MILES
175 - 100,000
195 - 50,000
215 - 25,000
235 - 12,500
255 - 6,250
275 - 3,125
295 - 1,500
315 - 750
335 - 325
355 - 160
375 - 80
395 - 40
Note: Transmission oil and filter should always be changed more frequently when driving with heavy loads (RVs), typically at least every 25,000 mile intervals, since converter outlet temperatures then normally far exceed the ideal 175° F.
[/font]
de·gen·er·ate
mrdoug is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
installin tranny temp gauge snowboardman2002us Newbie Tech 4 12-13-2012 04:36 PM
tranny temp gauge Kyota Interior/Electrical/Electronics 10 10-01-2007 08:18 PM
Auto Trans Temp Readings J-Man Early Tacoma Tech 3 05-19-2005 11:08 PM
Tranny Temp Gague joeylead Early Tacoma Tech 8 03-10-2005 12:15 PM
Auto tranny temp light ARB1977 Early Tacoma Tech 7 02-06-2005 06:28 PM
Privacy Policy
Links monetized by VigLink
