Go Back   TTORA Forum > Vehicle Specific Tech > Early Tacoma Tech
Thread Tools Display Modes
Old 05-20-2012, 04:14 PM   #1
cr500taco
Question Leaf springs
I am going to do a slight performance lift on my 97 Tacoma 4WD for the desert and trails. It has the stock coilovers and springs, right now, but I am going to get the Icon Coilovers and want to get Deaver springs for the rear. Deaver only has an add-a-leaf 1.5" lift available for my truck, but they have a full leaf replacement for the '98-'04 which is 1.5" lift, also. What's the difference between the '95.5-'97 and the '98-'04 springs and will the '98-'04 springs work on my truck with modification (I'm sure it will) and if so, is it worth the extra cost of the full leafs over the add-a-leafs and the effort of the modification to make the springs fit or should I just stick with the add-a-leafs? I think my OEM springs might need replacing, anyways.
cr500taco is offline   Reply With Quote
Old 05-20-2012, 04:35 PM   #2
TacoDell
truck ~n~ tow
TacoDell's Avatar
My Rig: '00 Tacoma
Default
A full leaf pak is always better then adding extra leafs to an oem leaf pak
Besides... after you've worn the new stuff out... ( will happen )
Deaver could assist you in renewing your spring paks, as well,
include refinements/adjustments... for a modest fee of course.
Not so with the oem leaf pak and aal design.
Tho' the aal's are supported by Deaver...
the oem leaf assembly is not.
95,5 - '97 are a shorter spring pack
and will not swap with the '98' - '04 tacomas
so... no
YES !
'00 Taco SR5, xtrcab, V6, 5-SP, 4X, and some extras...
Truck...
~n~ ...off road action photo's
Trailer...
Truck build --- Trailer build
TacoDell is offline   Reply With Quote
Old 05-20-2012, 04:55 PM   #3
cr500taco
Default
Your talking about performance wise?
Old 05-20-2012, 04:57 PM   #4
cr500taco
Default
so... no
I knew they wouldn't swap. So, mine are shorter from eye to eye? Will relocating the hangers on my truck to fit the 98-04 leafs do the trick and is that worth doing?
Old 05-20-2012, 05:11 PM   #5
ShowStop
Member Dismemberer
ShowStop's Avatar
My Rig: 95.5 Tacoma
Default
I have a set of custom Deaver springs on my 95 Tacoma. They will build custom springs if you don't want to switch to the 98-04 length packs.
Next Socal TTORA event - Miller Jeep Trail - June 22
www.ttora-socal.com
TTORA-Socal on Facebook
ShowStop is online now   Reply With Quote
Old 05-20-2012, 05:27 PM   #6
cr500taco
Default
Thanks, I'll check into that. But, I'm kinda thinking, too of just going ahead and get the 98-04 packs, because if my truck dies, I want to get either a 98, 99 or 2000 Tacoma and I'll be able to put it on that. It just depends on how much work it'll be to mod for the springs to fit my truck.
Old 05-20-2012, 05:32 PM   #7
ShowStop
Member Dismemberer
ShowStop's Avatar
My Rig: 95.5 Tacoma
Default
You will have to weld new spring pirches on the truck.
www.ttora-socal.com
Old 05-20-2012, 07:45 PM   #8
cr500taco
Default
Ok, that's what I was wondering, thanks.
Old 05-29-2012, 08:50 AM   #9
one_lastword
one_lastword's Avatar
Default
What about the Wheeler's Off Road Alcan packs for the 95.5-97 Tacoma's? They're 2.5" in an unloaded truck, but with a big rear bumper, shell, high lift, tools, etc. they'll drop down 1-1.5"
257,000mi and still goin' 1997 Tacoma 4x4, 5VZFE, Auto, ARB's front and rear, 4.10's, Treadwright Warden 31x10.50's, EBC Yellow Pads and PowerSlot Rotors, Lightforce 240's, Extreme Outback Extreme Aire Magnum Compressor, 34/78 RedTop starter, YellowTop D31 in the back, Xantrex Pathmaker, Assorted Search & Rescue Gear, CB, VHF, UHF Radios, Cellular Repeater, Federal Signal Lights and SS2000SM Noisemaker
one_lastword is offline   Reply With Quote
Old 05-29-2012, 07:13 PM   #10
Jtotheaceyota
Jtotheaceyota's Avatar
My Rig: 1999 Tacoma
Default
The All-pro has a nice pack for the price. I am very happy with mine so far.
99 Tacoma 3.4L 4X4 TRD, Custom bumpers, HID lights, Sliders, Boxed/reinforced frame, HDPE skids, E-locker skid, Fiberglass fenders/hood, Aerocatch latches, ICON coilovers/rear shocks, Camburg UCAs, Spindle/Coil gussets, All-Pro 3" leaf springs/ubolt flip, Energy 4.5" bumpstops, Brembo/Raybestos brakes with SS lines & proportioning valve, Magnaflow, Deck plate mod, In-cab snorkel mod, Gas cap diff breather mod, 1' flexible antenna, Recaro style XL seat, ScanGauge II, Sony, Emergency gear.
Jtotheaceyota is offline   Reply With Quote
Old 05-29-2012, 07:45 PM   #11
cr500taco
Default
I looked into those, but I think I would rather have Deavers.
Old 05-30-2012, 10:57 AM   #12
DreamMachine
DreamMachine's Avatar
My Rig: 03 Tacoma 4x4 TRD
Default
If you thinking about relocating your hangers anyway go ahead and look into converting to chevy springs. They are longer than the 98-04 springs also and flex really well. Not to mention they are cheap as hell and easy to replace.
I've got a set waiting for me to get off my ass and do the
I've bought 2 sets this last set I just bought is in better shape and I only paid $20.00 for them....
- Kole
From the GREAT STATE of TEXAS
2003 Tacoma Xtra Cab TRD 4x4
BFG A/T 33-10.50's
Front: FOX CO's (fabtech)
Rear: E-Locked, Tundra/Taco Hybrid leaf pack, 1.5" Downy Shackles & 10" Bilstein 5150's
Armour: TG Sliders
OverlandGuild.com
DreamMachine is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
So, Do I need new leaf springs??? smbundy13 Early Tacoma Tech 3 12-12-2011 10:38 AM
Leaf Springs and add-a leaf 2000 v6 Tacoma Zchornyak Parts/Electronics/Wheels & Tires For Sale 4 04-25-2010 08:29 PM
leaf springs w/ fabtec add a leaf camsbeoch Classifieds 6 07-02-2009 10:09 AM
Wagoneer Leaf Springs/ 63" Chevy Springs MTNRIDE Solid Axle Swap Tech 12 10-16-2008 01:53 PM
1st Gen 3 leaf & 4 leaf Springs brendog84cj8 Suspension 2 02-14-2007 12:38 PM
Privacy Policy
Links monetized by VigLink
