Sponsored Ad
Go Back   TTORA Forum > Vehicle Specific Tech > Early Tacoma Tech
Thread Tools Display Modes
Old 05-27-2012, 08:52 PM   #1
AlexXx
AlexXx's Avatar
Default aww snap...well crack
radiator has a hair line crack about 5" long on the opposite side of where the hose connects. Nothing is cooler than having fluid all over the top of your engine and across the hood. Had to patch it to stop loosing fluid, so some RTV came in handy for now.
Maybe a stretch, but is there any way to just buy the top plastic? I don't know if it is even possible to pry up the tabs. I might be in store for a new rad huh?
99 Taco: 3" lift, locker f/r , 4wd converted
91 Isuzu Trooper - 3.4, 5 speed, getting SAC'd with tons
AlexXx is offline   Reply With Quote
Old 05-27-2012, 10:23 PM   #2
TacoDell
truck ~n~ tow
TacoDell's Avatar
My Rig: '00 Tacoma
Default
JB weld it... see how far that gets you...
or just replace it... prolly around $ 100.
Or check with the radiator rebuild shops...
I'm sure they know where to get parts for a rebuild.
^ tho' if you don't do it right... could be a total waste of time.
it's likely the core is corroded and needing help as well.
If it were mine... I'd just order a new/rebuilt radiator...
and maybe try the JB weld while I wait for it to arrive.
I don't see a silicone holding for very long.
Originally Posted by Scootn2nature View Post
so fuck off you little 18 yr old lying ass punk.
'00 Taco SR5, xtrcab, V6, 5-SP, 4X, and some extras...
Truck...
~n~ ...off road action photo's
Trailer...
Truck build --- Trailer build
TacoDell is offline   Reply With Quote
Old 05-27-2012, 10:27 PM   #3
AlexXx
AlexXx's Avatar
Default
Thanks TD, I guess better safe than sorry. I'll be shopping around tonight. Taco is down for the week for some rebuildin', so I have time to wait for a new radiator to come in.
Old 05-29-2012, 11:04 AM   #4
ShowStop
Member Dismemberer
ShowStop's Avatar
My Rig: 95.5 Tacoma
Default
I've replaced 2 radiators (in separate vehicles) for this same issue. I've never seen then successfully patched. The heat and pressure makes patches only temporary. Replacement radiators for both vehicles (Tacoma and Mitsubishi) were about the same, $120 at wholesale cost.
Be aware of the size differences on Tacoma radiators. The radiators with the larger trans cooler are about 3 inches deeper. There are also 2 different widths.
Next Socal TTORA event - Miller Jeep Trail - June 22
www.ttora-socal.com
TTORA-Socal on Facebook
ShowStop is offline   Reply With Quote
Old 05-29-2012, 04:02 PM   #5
AlexXx
AlexXx's Avatar
Default
Thanks for the heads up! Through my brother, NAPA quoted him 105 for the spectra rads. I read good and bad, mostly good about them. They treat my brothers shop really well and they would swap it out if the warranty ran out or it craps out on me, so I'll give it a go.
Old 05-29-2012, 04:10 PM   #6
tacoma_2002
tacoma_2002's Avatar
My Rig: 2002 Tacoma
Send a message via Yahoo to tacoma_2002
Default
I replaced mine about 5 months ago. I had a hairline crack approx 2inches directly across from the top hose. I sanded it and cleaned it really well with alcohol and then applied JB weld. After letting it sit for 24 hrs I started the truck and drove it. JB weld held fine for about 3 days at a time (30 minute commute each dayto work). Replace the thing and be done with it.
2002 Xtra Cab TRD Taco 3.4 Manual
Super White 2
Lifted, Locked, Armored
2007 Double Cab TRD Taco 4.0 Auto
Silver Streak Metallic
2.5 SAW's, 2.0 Icons rear with Deaver pack
Originally Posted by SafetyDang View Post
Look at my picture I posted you can see that you may need 2-3 more inches.
tacoma_2002 is offline   Reply With Quote
Old 05-29-2012, 04:12 PM   #7
AlexXx
AlexXx's Avatar
Default
I am, the rtv held up for a little over a week haha. Hopefully have it by friday, NAPA is ordering it today.
Old 05-30-2012, 12:46 PM   #8
vegaskurt
vegaskurt's Avatar
Default
I have a spectra that I just put in mine. Seems fine and does the job. My only gripe is the the plastic part that you attach the radiator cap to. Mine had to be sanded a bit to make the OEM cap work.
1997 4runner SC V6 | URD 7th | Stubbs Sliders | SAS | FROR FF Kit
vegaskurt is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Wes needs his crack =ACID RAIN= Off Topic 6 09-19-2009 02:01 AM
Got some crack Friday 954RUNNER General Discussions 6 06-24-2008 07:59 PM
LCE 3RZ header crack! Philfab Performance/Engine/Exhaust 51 04-21-2008 05:22 PM
Crack in my Windshield Talanor Off Topic 10 11-28-2007 06:20 AM
Exhaust Man. Crack? Ripcurlsurfin96 Early Tacoma Tech 3 03-14-2005 02:41 PM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
