Welcome to the TTORA Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
#1 |
Anybody in Nor Cal know a good shop who would install UCAs on my Tacoma? I'm getting lazy these days and don't want to install them myself unless I have to.
I would apprechiate any leads. Thanks. Josh
2005 Tacoma Double Cab 6-speed TRD offroad 2.0" SAWs Deaver 10/12 pack hybrid 305/70R16 Yoko Open Country M/T My Taco Project: http://64.150.166.23/josh/taco/ Last edited by Doss; 02-03-2006 at 12:48 PM. Reason: title |
#2 | |
Jon '05 Double Cab 4x4 V6 SR5 Auto White Mods: Fabtech DirtLogic 2.5 coilovers and Total Chaos UCAs up front, Deaver springs and Bilstein 5150's in the back, American Racing Mojave 16x8, BFG M/Ts 265/75/16, Demello Bolt-on sliders. '01 Double Cab 4x4 V6 Auto TRD Black, you will be missed. '89 BMW M3 Alpine White Last edited by SP Jon M3; 02-03-2006 at 04:41 PM. |
#3 |
Bought, not built.
![]() Join Date: Oct 2005
wow...i can't wait to get to the point where i can ask something like this...maybe i should get off my ass and, like, work or something...
Once I wear out the soles of my shoes, I'll be back on my feet! 03 tacoma - occasional runs to the mall, helping friends move, etc. 87 runner - occasional runs to the woods, helping friends move their bowels, etc. |
#4 |
Yeah Jon is right I should probably just do the work myself and save some $. Thanks by the way for all the info and pics too.
One thing I am still concerned about though is once the front of the truck is off the ground and I pop off the stock upper control arm wont the coil over be free to decompress to full length. I which case how do you compress the coil over back down so that the new UCA will reach the rest of the assemply?
2005 Tacoma Double Cab 6-speed TRD offroad 2.0" SAWs Deaver 10/12 pack hybrid 305/70R16 Yoko Open Country M/T My Taco Project: http://64.150.166.23/josh/taco/ |
#5 |
Once you lift the truck with a jack the coil will extend to maximum length so it should be all free. unbolt the top three bolts from teh UCA. DO NOT LOSTEN THE BIG MIDDLE ONE. Take the coil out after taking off to bottom bolt. Unbolt UCA and put in new one and reattach the coil strut assembly. its pretty easy. it may be hard to visualize but jack up the truck and take the tire off and you will see what im talking about. just remember not to take the middle bolt out because that attaches to the topplate to the strut and that will hurt you when the coil extends instantly.
EDIT: just saw you have an 05. this should all still apply but im not a 100% posivtive. there might be a different combination of top bolts but just remember to stay away from teh bolt that attaches to the strut. should still be easy.
2010 4cyl 4x4 5speed Access Cab Last edited by tacoma87; 02-03-2006 at 01:41 PM. |
#6 | |
Ze Moderator Ya
www.chaosfab.com www.foxracing.com www.deaverspring.com www.mullenfabworks.com My truck is for sale!!! - "When a cop flashes his lights at you he's not really asking you to pull over. He's challenging you to a race." - The Book of the Piece |
#7 |
When I installed my UCAs on my '05 I did not need to unbold the COs at all.
1) Lift truck 2) remove wheels 3) place floor jack under outer lower ctrl arm, do not compress the arm at all, just have it there for support. 4) remove ball joint bolt 5) tap ball joint out of spindle, the spindle will fall towards you a few inches 6) bend fender out of the way 7) remove main pivot bolt 8) remove stock arm 9) place new UCA with new bushings use grease and washer/spacers in position on the frame 10) install main pivot bolt, and torque to spec 11) Line uniball with the spindle, you might need to use the jack to push the spinde up in place 12) install bolt through uniball and spinde then thread the nut on the bolt 13) torque to spec. 14) retorque all bolts 15) grease zerk fittings (optional) 16) replace wheel, torque lugs to spec (83lbs I think) 17) repeat on other side 18) drive truck around and hit some speed bumps to settle suspension 19) go get an alignment * Driver's side requires (make it easier) removal of battery. You can see some pics of me installing the UCAs here http://web.mac.com/jbryan/iWeb/My_20...TC%20UCAs.html NOTE: This is how I did it. I'm can't be held resonsible if you try it this way and damage your truck. Took about 30-45 min/ side.
Jon '05 Double Cab 4x4 V6 SR5 Auto White Mods: Fabtech DirtLogic 2.5 coilovers and Total Chaos UCAs up front, Deaver springs and Bilstein 5150's in the back, American Racing Mojave 16x8, BFG M/Ts 265/75/16, Demello Bolt-on sliders. '01 Double Cab 4x4 V6 Auto TRD Black, you will be missed. '89 BMW M3 Alpine White Last edited by SP Jon M3; 04-20-2006 at 08:57 AM. |
#8 | |||
Jon '05 Double Cab 4x4 V6 SR5 Auto White Mods: Fabtech DirtLogic 2.5 coilovers and Total Chaos UCAs up front, Deaver springs and Bilstein 5150's in the back, American Racing Mojave 16x8, BFG M/Ts 265/75/16, Demello Bolt-on sliders. '01 Double Cab 4x4 V6 Auto TRD Black, you will be missed. '89 BMW M3 Alpine White Last edited by SP Jon M3; 02-03-2006 at 07:23 PM. |
#9 |
its a lot easier to do it your self, plus you learn more about your truck
#10 | |
2003 4wd/Donahoes/Camburg UCA's/7-pack Deavers/Bilstein 5150/Mickey Thompson C2 wrapped with BFG A/T 285/75-16 |
#11 |
Mud’s the devil
Yeah, mine were easy, but I do have an older pickup.
a couple of things to consider. Use high quality polyurethane grease, and torque the main bolt at ride height that way everything is set there rather than at full drupe. This will help with the squeaks.
FOR SALE
Built 95.5, std. cab, Manual, 3.4 v6 Tacoma http://www.tacomaterritory.com/forum...d.php?t=146226 |
#12 | |
Excellent. Thanks. I guess I will be doing the install myself. Mine as well I've installed everything else on the truck. Time to call Demello and get some UCAs Thanks Everyone for your input.
#13 | |
http://web.mac.com/jbryan/iWeb/My_20...TC%20UCAs.html There is one where the stock UCA has been removed and the suspension is just hanging. You inquired about that earlier.
Jon '05 Double Cab 4x4 V6 SR5 Auto White Mods: Fabtech DirtLogic 2.5 coilovers and Total Chaos UCAs up front, Deaver springs and Bilstein 5150's in the back, American Racing Mojave 16x8, BFG M/Ts 265/75/16, Demello Bolt-on sliders. '01 Double Cab 4x4 V6 Auto TRD Black, you will be missed. '89 BMW M3 Alpine White |
#14 |
Thanks Jon and everyone else for your input...
Camburg UCAs are on order and I should be able to install them next weekend and then finally get the truck aligned correctly.
#15 |
i'll install them for free, along with a check for one hundred million dollars, a 12 pack of beer and a smut magazine.
'95 Taco-SR5-AT-ADD-SAW 2.0-Deaver 8 leafs Ask me how I'm at 223k miles Oh, what a feeling! AMSOIL dealer 500001
#16 |
Well took about two hours but the UCAs have been installed. The truck is currently at the alignment shop. Hopefully they can align it now with the new arms.
Thanks for the write up Jon, I had one question though. What did you do with the brake line that was attached to the stock UCAs with the 10mm bolt? In your picture it looks like you just have them sitting on top of your new UCAs. I zipped tied mine to the new UCAs but I was wondering if you had a better method. Thanks, Josh
#17 | |
So you did the install yourself? Got any pics?
#18 |
Yeah I ended up installing them myself. I'll throw some pics up tomorrow.
#19 |
Some pics I took during the install. There are very few I always forget to take pics once I start.
stock stock unbolted My SAWs are too damn dirty
#20 |
Hillbilly Deluxe
Looks good... I'm trying to find the courage to install my set. I have an 04, so its a little different.. there are 2 bolts for the Ball Joint. One on the top, and one that connects to the spindle. Will I be able to accomplish this by getting one of the BJ presses from Harbor Freight? The have a 3 piece and another kit for 4WDs... I have all the tools but the press.
Camburgs, Deavers, Tunes and a Locker...That's How I Roll... 04 PreRunner 3.4L - ODO 52330 265/75/16 Cooper STTs |
#21 | |
Coastie
__________________________________________ '04 DC Non-TRD PreRunner lifted, locked, armored, exhausted, barely driven onroad |
#22 |
Ok guys,
Less than 3K miles on the new UCAs and I've got creaking going on when I turn the wheel. Not the squeaking that everybody has talks about with the aftermarket UCAs, but creaking like an old door. It doesn't bother me but it is definatly noticable when you turn the wheel. Josh
#23 | |
Coastie
Most of us call this the 'sound of performance'.
#24 | |
I use Super Lube and this kills the noise, but I have to clean the uniballs about every month or two. And reapply.
| Sponsored Links |
| Thread Tools | |
| Display Modes | |
| Need help with UCA install | SP Jon M3 | Late Tacoma Tech | 24 | 03-21-2006 07:35 PM |
| gear/locker install coming up | Nullifier | Early Tacoma Tech | 0 | 11-29-2005 11:37 AM |
| Budbuilt Tacoma tcase clocker kit install | lsloth | Early Tacoma Tech | 21 | 09-19-2005 10:45 AM |
| ARB locker install in so-cal | DCabTaco | Early Tacoma Tech | 2 | 07-26-2005 06:23 PM |
| Gear Install - Is master install kit required? | Vince | Early Tacoma Tech | 5 | 03-25-2005 11:48 AM |
