Sponsored Ad
Go Back   TTORA Forum > New Members Area > Newbie Tech
Thread Tools Display Modes
Old 05-30-2006, 03:11 PM   #1
tennessee01tacoma
tennessee01tacoma's Avatar
My Rig: 2001 Tacoma
Default Gear Ratio
I have an 01 Tacoma Sr5 4x4 with a 2.7 and 5spd it has 265/75/r16 tires which are 31.75" tall and 10.5 inches wide.
does any one know what gear ratio I have
01 Tacoma 4x4 xCab 2.7l, Bilstein 5100's, Top Gun Customz Lift Shackles, HardKnox Fabworks Sliders, Custom Sway-bar Disconnects 285/75/r16
tennessee01tacoma is offline   Reply With Quote
Old 05-30-2006, 03:17 PM   #2
da'Burd
if it sparkles & pleases
da'Burd's Avatar
Send a message via MSN to da'Burd
Default
try this:
http://www.tacomaterritory.com/wiki/...php/Gear_Codes
1980 Std. Cab, 20R 4x4
da'Burd is offline   Reply With Quote
Old 05-30-2006, 03:26 PM   #3
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
if your tires are listed on the sticker as 265/70/16s (31x10.50s) (not just added by the dealer but from the factory) you should have 4.30s.
the tires you list are aftermarket and not the OE size (32x10.50s).
but, check your dr side door codes or have your dealer run your VIN#.
Originally Posted by Teryx View Post
Yeah, well, I'm just glad I snagged a few Spector cans before EPA converted them to Sphincters
Originally Posted by Tacoma Jake View Post
Lube may be your best friend (depending on location).
'00 Excab Tacoma, 2.7, 5sp with a Bunch-o-mods
Inchworm Rock Walkin' Gear
hytenor is offline   Reply With Quote
Old 05-30-2006, 03:53 PM   #4
tennessee01tacoma
My Rig: 2001 Tacoma
Default
I found the same link with the wonderful search feature and my code is B07A which means 4.30's but I did see one thing on the link about the same code except with 4.56's
btw where can I find the color that goes with my paint code 209
Old 05-30-2006, 03:55 PM   #5
hytenor
hytenor's Avatar
My Rig: '00 Tacoma
Default
some (very few) AT prerunners wound up with 4.56s but only AT 4x4s with the 2.7 got that ratio on a regular basis after '01.
your dealer will have the paint codes
Old 05-30-2006, 08:10 PM   #6
gsgallant
Default
I've answered this question here. Check it out... you should be able to get what you need. The gear codes (and gear code lists that you will find online) are not always accurate. The "tire rotation" method always works.
2002, 4Runner, Auto, 3.4L, 5VZ-FE
Mobil 1 Synthetic Oil / K&N Oil Filter - Mobil 1 75W90 Synthetic gear oil in Front, Rear and Transfer, Extended rear diff breather, Westin Step Bars, "4-air" system for airing up/down tires, Deckplate Mod,
Andymod, Dual battery setup with Optima blue top deep cycle auxiliary battery
Mods to Come:
Auxiliary fuse box,
Full time power to aux power plugs from aux fuse box
gsgallant is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
gear ratio TacomaTRD05 Early Tacoma Tech 17 02-03-2006 01:14 PM
factory gear ratio vs. tire/engine combination swimmer Newbie Tech 2 08-13-2005 01:40 AM
Gear ratio CajunTacoma Newbie Tech 1 07-25-2005 05:47 PM
tire size and gear ratio calculator The Shocker Tires/Wheels 5 02-02-2005 03:21 PM
What gear ratio did my 2001 prerunner v6 come with? TexasTRD Suspension 2 01-18-2005 01:20 AM
Sponsored Ad
Privacy Policy
Links monetized by VigLink
