Welcome to the TTORA Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
#1 |
from previous:
colsoncj: We still need to get together and go wheelin sometime, but I dont know if I'll ever get my rig back together... I just got the front taken care of and now the rear needs shoes, wheel cylinders, and possibly a new wheel bearing.... If it does need all that, I'm selling the 3rd and putting a narrowed and shaved 14B in it. gittinit: A shaved 14 bolt huh? So you gonna put some 42s on that rig? I love the with and ground clearance of my toy stuff, heck I even shaved my rear diff just to get that litle extra, and it has paid off more than once. I used to own a chevy blazer with 3/4 ton axles and I had shaved the 14 bolt. Even with the 14bolt shaved and 36s it would still hang up where my friends toyotas on 33s wouldn't. colsoncj: I know, I know.... problem is i keep breaking crap... I fried the wheel bearings again, and they only had 30K on them.... I'm lookin for some stoutness.... I may regret it I know, but I'm lookin for some more reliablilty, any thoughts... PM me if you want, I know we are getting a little On a side note, I also need the low down on the 22R's: with these 84's and the 85 I'm a little out of my element, I just know the fuely stuff... gittinit: I aint worried unless someone else is.....do we have mods?, mabye thay can move this to chit chat, we do have a talk section right? Sounds like someone didn't use oem bearings, although I have had good results from timken in the past. 22r lowdown, well thats easy I can ramble on abut old school toy 4cylinders all day, but 1st one question....Which do ya want to run propane, efi or carb? Let me know so I don't confuse you with all the closed/open chamber, and intake runner/compression mumbo jumbo. |
#2 |
Well, I know plenty about the 22RE, its the carbed versions I'm wantin to know more... Also, I know I had this info somewhere, but how do you tell the difference between a 20R and 22R, and can you convert a 22R to a 22RE without goin nuts?
I didnt use OEM bearings in the rear, I believe they were federal mogul... I also think it got a little water in it from a previous trip before I changed out the fluid (which was a little watery, but not bad at all. Looked like it hadnt been in there long.) I need to extend my diff breather, never had a problem until I knocked it off the housing, which I just noticed when I drained the fluid the last time... |
#3 |
And after thinking about it some more, I may stick with the toy rear... I dont think I want to go through the mess of swapping, and now that I have this 84, it'll get the rear out of my 87 when the time comes to swap to something more heavier duty (about the same time I swap a roller 302 in it hopefully...)
#4 |
79-80 model pickups and such were offered with the 20r motors. I currently have 2 so I can get some pics if ya want. The easiest way to identify a 20r is...If it running stock carb the part of the carb where the breather sits is round. The 22r carbs will be more square with one side being bigger than the other. I forgret the name of the particular shap, but I think its called a trapazoid.
Here is a pic of the 22r carb ![]() Here is a pic of the top of the 20r carb. Notice the valve cover is from a later model 22r motor. ![]() The easiest way of identifying blocks between 20r and 22r is by the tag on the drivers side just behind the alternator. Here is a pic for referance.
Whats left of a 85 Toyota, 22r Slightly Modified, Got propane, lots of tube n stuff. ![]() =Greene County Crevise Crawlers= |
#5 |
perfect...
now, any differences between 22R and 22RE? (besides fuel injection...) i.e. head, timing cover, etc... |
#6 |
#7 |
Yes you can convert a 22r to re with little to no issues. There are 2 different versions of the 22r motor. The 1st was the tall deck versions(open chamber), and the second being the shortdeck versions.
Both can be converted to use the efi from the 22re series motores, but the later shortdeck motors are the best choice, and are better suited. I have read somewhere that the cams were ground slightly differently between these the shortdeck(sd) 22r, and the re series motors, but I have no proof to confirm this. The (td) 22r is the worst canidate for efi swaps becouse there is no threaded hole in the block for the knock sensor. (early celica efi systems didn't use the knock sensor) I have suscessuffly helped a friend swap a 84 tall deck 22r motor into his efi equipped 85 4runner by simply relocating the knock sensor to the older block by drilling and tapping a hole in a factory boss on the older style bock. It is my opinion though that this created a slight loss of power becouse the knock sensor was getting a delayed reading and compensating by adjusting the timing appropriately. This too could be compensated for with a lc engeneering adjustable timing gear, but he has since lost interest, and this toy now sits. The easiest way to use a 22r in an efi application would to source a shortdeck 22r which were offered since 1985. Here is a pic of the saturn shaped casting in the side of the 22r block that allows easy identification. Notice the square 22r identification ta in the left hand side of the pic. Now next to the mount bolts for the coolant crossover tube mount bolts there is a rounded shape with ears...thats the identifying shure fire way of knowing you have a short deck block.
#8 | |
I thought there was a difference in the 22Rs... now I know for sure. I remember talking with a buddy and him mentioning the deck height difference. He figured it out from the difference in timing chains, so I'll assume the timing covers are different as well. Any idea how to tell the difference in timing covers? I'm assuming it would just be a simple height measurement, but I'm unsure of what the numbers are. Also, are the heads the same between the sd and td versions (cam excluded)? |
#9 | |
Found this:
#10 |
So apparently the head is different between the sd and td.... now how do you tell the heads apart?
#11 | |
Here is a pic of a sd combustion chamber.
Whats left of a 85 Toyota, 22r Slightly Modified, Got propane, lots of tube n stuff. ![]() =Greene County Crevise Crawlers= Last edited by gittinit; 11-02-2007 at 08:49 PM. Reason: add pics |
#12 |
I have pics of this too but I can't seem to find em. My photobucket acct is a mess. I need to spend a mont just organizing it but I'm afraid it will break some of the links I want hanging aroud here and there on the net.
#13 | |
More info I found: The short deck has a slightly lower block than the tall deck. (duh) The short deck uses a 2 less links in the timing chain. 96 vs 98 links I have been told that the 96 link single row chain can be upgraded to a double row by using a modified early 22R timing cover, oil pump, drive spline. The 20R exhaust manifold had air injection that mounted on the manifold top and no oxygen sensor mount. The 22R does not and some do and dont have an oxygen sensor mount. The 20R exhuast manifold outlet has a single outlet into the exhuast pipe. The 22R exhaust manifold had dual outlet. The 20R exhaust manifold usually had 1 lower center mount stud. The 22R exhaust manifold usually had 2 lower center mount studs. Some early 22R exhaust manifolds had single lower center stud hole. Some 22R exhaust manifolds had both configs of holes and had 3 holes. Aftermarket exhuast manifolds usually fit all 20R/21R/22R by having all possible holes. (http://ourworld.compuserve.com/homep...pho/eng20R.htm) On some of that I'm not so sure, I think the 22R also had the air injection. Plus, after 20 years, who knows what has gotten swapped out.... |
#14 |
lol, i completely understand....
#15 |
some great info:
http://www.babcox.com/editorial/ar/ar119838.htm EDIT: it has the pictures you are looking for (diffences in the heads...) |
#16 |
Measurements for ref: (I know, im answering my own questions....)
Proper Deck Heights – Blocks & Heads Whenever you go through an engine or cylinder head re-build, there will be some amount of "re-surfacing" that has to be performed to either the block or the head. Most frequently, it's the cylinder head. This is also known as "decking." For machining purposes, deck height on an engine block is the measured distance between the "Center Line of the Main Journal" to the "Deck Surface". This can only be performed with the engine block disassembled and the crankshaft removed. Toyota factory heights would be: Early 20R Blocks 75-80 9.120" Early 22R Blocks 81-84 9.120" Late 22RE Blocks 85-95 8.930" For easy identification purposes, with the engine still assembled, deck height on an engine block is the measured distance between the "Oil Pan Rail" (bottom of the engine block) to the "Deck Surface" (top of the engine block). Toyota 20R, 22R and 22RE engine blocks have these factory deck heights: Early 20R Blocks 75-80 11.280" Early 22R Blocks 81-84 11.280" Late 22RE Blocks 85-95 11.090" Deck height on a cylinder head is the distance between the bottom of the "Camshaft Journal" to the "Surface of the Cylinder Head" itself. Toyota 20R, 22R and 22RE cylinder heads have these factory deck heights: Early 20r/22R Heads 75-84 3.290" Late 22R/22RE Heads 85-95 3.130" These numbers are especially important if you have purchased a pre-owned engine and have no idea what, if any, modifications were made prior. In other words, it's a starting point in establishing how much re-surfacing has already been performed to the head or block. Example: If you have a late 22RE cylinder head that has a measured deck height of 3.110", then it is probably safe to say that the head has been "decked" approximately 0.020". c/o LC Engineering |
#17 |
Did you know that 20 r motors and 22r motors all use the same crank and conecting rods from 79 through 95?
Early 20R Blocks 75-80 9.120" Early 22R Blocks 81-84 9.120" Another weird fact is that even though these blocks had the same deck height the 20r uses flat top pistons and the early (td)22r uses dome pistons.
#18 |
Here are a couple pics of the 20r and the 22r exhaust ports. Notice the 20r has round ports while the 22r has teardrop shaped ports.
20r ![]() 22r
#19 | |
#20 | |
EDIT: the ID difference between the two being a 20R has round intake ports in the head and the 22R has square.... |
#21 |
Hey thats great! I'm gonna have to save that for future reference....for schoolin newbs.
#22 | |
Please correct me if I'm wrong. There wasn't an overall desighn change , but instead just a little tweaking on toyotas behalf. Hell the 20r heads flow better than the 22r heads do, why would toyota change for the worse?
#23 |
I dont know... I do know the heads are different, and have different combustion chamber sizes... beyond that your knowledge is probably better than my guess.
#24 | |
Round Intake Port / Round Exhaust Port 80 / 81cc Chamber In. Valve Dia. 43mm / Ex. Valve Dia. 35mm -------------------------------------------------------------------------------- 1981 / 84 22R / RE Cylinder Head Square Intake Port / Round Exhaust Port 82 /83 cc Chamber In. Valve Dia. 44.5mm / Ex. Valve Dia. 36.5mm -------------------------------------------------------------------------------- 1985 / 95 22R / RE Cylinder Head Square Intake Port / Pear Shaped Exhaust Port 58 cc Chamber or 22RET (Turbo) In. Valve Dia. 44.5mm / Ex Valve Dia. 36.5mm c/o LC Engineering |
#25 | |
Deck Height 11.090" Stock Bore 92.0mm - 3.622" Maximum Over Bore 93.0mm - 3.6662" Big Bore Forged Piston Kit 94.0mm - 3.701" isn't that what I wrote? ![]() Just to clearify. saturn= lazerblock=sd=short deck=flattop pistons= closed chamer heads= flat top pistons= 85-95
#26 | |
1) its cheaper 2) Some regulation (read: emissions) |
#27 |
I do have some more questions for ya... what do I need to know about the carbs? any tricks for adjustment, problems, things to remove or add....
#28 | |
![]() EDIT: I also want to say thanks for all the info and help! Last edited by colsoncj; 11-02-2007 at 09:35 PM. Reason: cause gittinit needed a thank you |
#29 | |
I have considered propane though becouse it floods when I stand the truck on the rear bumper. My carb will also starve its self of fuel when I'm on my pass side, it will run on the driverside though.
#30 | |
| Sponsored Links |
| Thread Tools | |
| Display Modes | |
| 3.4l swap chit chat | thefatkid | Performance/Engine/Exhaust | 27 | 02-08-2008 11:04 AM |
| funny chit - | TBob | Off Topic | 2 | 08-22-2006 01:37 PM |
| holy chit?? | BlingTaco | Off Topic | 1 | 01-12-2006 04:52 PM |
| This MF Chit Sucks | TacoManny98 | Off Topic | 9 | 12-21-2005 03:01 PM |
| Member Rigs and Featured Rigs now operational | TOYMINATOR | News/Error Reporting/Suggestions/Help | 31 | 08-09-2005 09:01 AM |
